ESRI ArcGIS APIs generates the “Unable to complete operation” error code 400 for various reasons, such as:
• Wrong attribute names specified in the AssetClass lookup table.
• The query syntax does not conform to the standards. Refer to the ESRI ArcGIS documentation to make sure the correct syntax is used.
For information about the limitations and workarounds in this integration and in the respective applications, and the known issues, see the ESRI ArcGIS Integration to Oracle Utilities Work and Asset Cloud Service Release Notes included in this release. The document is available on the Integrations page on Oracle Help Center.
