Batch Jobs
ESRI ArcGIS to Oracle Utilities Work and Asset Cloud Service/Oracle Utilities Work and Asset Management
The following batch processes need to be run in sequence to load all data:
Step
Batch Code
Description
Additional Parameters
1
W1GISUPL
GIS File Upload
• fileName: Name of the file or files to be uploaded. For multiple files, the parameter supports the “glob” syntax for using wildcard characters.
• filePath: The file path where the output should be placed.
2
W1-CMSYN
Composite Sync Request
• State: PENDING
• BO: W1-CompositeSyncReqGISAsset
3
W1-SIOPE
Ongoing Sync Request -
Pending
• State: PENDING
• BO: W1-OngoingSyncRequestLocation
4
W1-SIOPE
Pending
• State: PENDING
• BO: W1-OngoingSyncRequestAsset
Oracle Utilities Work and Asset Cloud Service/Oracle Utilities Work and Asset Management to ESRI ArcGIS
The following batch process need to be run to extract asset information to a file:
Step
Batch Code
Description
1
W1GISEXT
GIS File Extract
• fileName: Name of the extract file. The file will be replaced if it already exists or created if it does not.
The parameter value is defaulted to “WACS_<assetClass>_{BN}_{RN}_{TN}.json” where the variable {BN} is the respective batch number, {RN} is re run number and {TN} is thread number. The <assetClass> variable will be replaced with the GIS asset class value followed by the file number based on the Maximum Records Per File parameter. A separate file for each GIS asset class is created if the <assetClass> variable is provided.
Note: If a specific AssetClass is provided by replacing the <assetClass> placeholder, a sequential number is prepended to the file name and must be removed manually. The default parameter value should be used for batch processing to ensure files are generated in a format that the OU WACS ArcGIS Asset Update process can correctly identify and process.
• maxRecordsPerFile: Parameter value is defaulted to 300.
Note: Larger values may result in requests exceeding ArcGIS API limitations.
• fileFormat: Parameter value is defaulted to JSON.
