Configuring Lookups
The following table lists the lookups that are part of this integration.
Lookup Name
Integration Name
Purpose
OUTL-BRT-ArcGIS_WACS_ConfigProps
• OU WACS OIC GISMappings Sync
• OU ArcGIS WACS Assets Sync
• OU ArcGIS WACS Initial Assets Sync
• OU ArcGIS WACS Incremental Assets Sync
• OU WACS ArcGIS Assets Update
Generic properties used in the integrations business logic and mappings.
OUTL-BRT-ArcGIS_WACS_Email_ID
• OU Common Notification Handler
Provide email information to send the notification.
OUTL-BRT-ArcGIS_WACS_AssetClass
AssetClass information that have been refreshed from Oracle Utilities Work and Asset Cloud Service and adapted by the customer ESRI ArcGIS implementation.
OUTL-BRT-ArcGIS_WACS_DateTimeFields
Maps ArcGIS date fields (coming from WACS) to the corresponding ArcGIS DateTime field types. If a Feature Layer ID is specified, the transformation applies only to that layer; else, it applies to all layers.
_ESRIConnections
Supports Dynamic Connection functionality by mapping the ServerId per AssetClass in OUTL-BRT-ArcGIS_WACS_AssetClass to a corresponding ArcGIS REST ConnectionId, which is selected at runtime.
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Projects.
3. Select the project and then navigate to the Lookups section of the project.
4. Select the lookup to edit.
5. Make the necessary changes.
6. Click Save and Close.
