Limitations and End-of-Life
The legacy integration depends on ESRI technologies that have now been retired. ESRI retired the ArcMap and ArcObjects platforms in March 2026. As a result, the legacy integration now faces the following limitations:
ArcObjects-based tools no longer receive support or updates after March 2026.
Support for ArcGIS Server 10.9.1 ends in December 2027.
The GIS JAR used by the legacy integration no longer receives updates.
