Integration Configuration
Configure the integration components required for the modern Oracle Integration Cloud-based integration.
• Set up Oracle Integration Cloud.
• Configure Object Storage or the applicable file exchange location.
• Configure and verify Oracle Integration Cloud connections.
• Confirm file drop locations, permissions, and connectivity between Oracle Utilities Work and Asset Cloud Service, Oracle Integration Cloud, and ArcGIS.
