Post-Migration Tasks
After the ArcGIS upgrade and integration setup are complete, perform the following Oracle Utilities Work and Asset Cloud Service migration activities:
If Global IDs changed, run the File Split Template batch process, if needed.
Run the ArcGIS ID Update batch process to update Oracle Utilities Work and Asset Cloud Service with the new Global IDs.
Re-extract asset, location, and work location data from Oracle Utilities Work and Asset Cloud Service for validation.
Configure ArcGIS to Oracle Utilities Work and Asset Management mappings in extendable lookups.
Configure Oracle Utilities Work and Asset Management to ArcGIS mappings in extendable lookups.
Configure real-time messaging for work location synchronization.
Remove all legacy ArcGIS synchronization batch jobs from the scheduler.
Register the new file-based inbound batch jobs.
Register the new file-based outbound batch jobs.
Enable ESRI ArcGIS Integration in the Oracle Utilities Work and Asset Management configuration.
