Validation
Validate the integration before returning the system to normal operations.
• Test the asset and location synchronization from ArcGIS to Oracle Utilities Work and Asset Cloud Service using a small dataset.
• Test the asset synchronization from Oracle Utilities Work and Asset Cloud Service to ArcGIS using a small dataset.
• Create sample work locations and confirm end-to-end real-time messaging.
• Verify that the generated Global IDs are returned and stored correctly in Oracle Utilities Work and Asset Cloud Service.
• Review batch logs and error tabs for failures or warnings.
• Confirm that files are generated, transferred, and processed successfully.
