Adding Enumeration Values to OFS Property
Oracle Filed Service includes enum properties that need to add values to Oracle Utilities Customer Cloud Service, such as SQI, TOU, UOM, meter configuration type, etc.
To add values to the enum property:
1. Login to Oracle Field Service.
2. Navigate to Configuration > Resource, Activities, Inventories > Properties.
3. Search for the property with label.
4. Click Modify Property.
Values field shows a combination of Description[id]. Example: Simple Electrical[E-DEFAULT]Modify property window.
5. In the English field, enter the description and code.
6. Enter "Item" to verify an item as part of custom activity and activity as part of ID. Example: Item[Custom_item_activity_type]
7. Click Add to add the values to the Values list.
8. Click Update to save the value to the property.
The table below lists the properties to be updated to add custom values apart of the demo values that are part of the accelerator.
OFS Property
Oracle Utilities Customer Cloud Service Admin Table
Service Point Status Code
New Item Type
Device Type
New Meter TOU
Time Of Use
Customer Contact Type
New Meter SQI
Service Quantity Identifier
Disconnect Location
Disconnect Location
Service Point Instructions
Service Instructions
Service Point Warnings
New Item Model
Model
New Meter Model
Model
New Item Manufacturer
Manufacturer
New Meter Manufacturer
Manufacturer
New Meter UOM
Unit Of Measure
Item Configuration Type
Device Configuration Type
Unit Of Measure
Unit Of Measure
Time Of Use
Time Of Use
Premise Type
Premise Type
Service Point Type
Service Point Type
Meter Configuration Type
Remark Type
Remark Type
Premise Warning
Cancellation Reason
FA Cancel Reason
Meter ID Types
Meter ID Type
Read Type
Read Type
9. Add entry to the corresponding Oracle Integration Cloud look up.
Example: After adding value to the Manufacturer properties, add an entry to the SOMOFSC_Manufacturer Oracle Integration Cloud lookup.
To add an entry to the lookup:
1. Login to Oracle Integration Cloud.
2. Navigate to Designer > Lookups.
3. Search for the respective lookup.
Example: SOMOFSC_ManufacturerLookup details.
4. Click +.
5. Enter the SOM code in the SOM_Manufacturer column.
6. Enter the ofsc enum field ID in the OFSC_Manufacturer column.
7. Click Save.
8. Deactivate and activate the integration using the lookup.
