Managing Web Service Catalog
The web service catalog is used by Oracle Integration Cloud to communicate with the corresponding application. It defines the services to be accessed by the Oracle Utilities Adapter. It is configured in the Catalog URL in the Oracle Integration Cloud connection.
To configure the catalog in Oracle Utilities Customer Program Management Cloud Service:
1. Login to Oracle Utilities Customer Program Management Cloud Service.
2. Navigate to Admin > [W or Integration] > Web Service Catalog. Alternatively, you can search for the Web Service Catalog page from the Search menu.
3. Select REST Web Service Class.
4. Add the following REST inbound web services to the catalog.
5. If applicable, for outbound messages, add the External System that was set up previously.
For more information about configuration, refer to the
Oracle Utilities Work and Asset Cloud Service documentation on
Oracle Help Center.
