Importing Oracle Accelerator Project from Oracle Integration Store
To import an Oracle Accelerator Project from Oracle Integration Store:
1. Navigate to the Oracle Integration Cloud Home page.
2. Click Browse Store.
3. In the store, search for any (or combination) of the following keywords:
• UGBU
• CPMCS
• DERMS
• Customer Program Management
• Distributed Energy Resource
4. Select the correct version of “Oracle Utilities Customer Program Management Cloud Svc. to Distributed Energy Resource Mgmt. System” from the search results and click Get.
5. Verify that the new project appears in the project list with the status “Configured”, indicating that the connections have not yet been fully completed.
6. Click Project Edit and complete the required verification and configuration steps. For detailed instructions, refer to the Verifying the Project Import and Configuring Connections in Oracle Integration Cloud. Then, click Next. My Oracle Support portal opens.
7. After the configuration is complete, activate the integration either by:
• Clicking Activate in the Design page of the project.
• Or, activate the latest deployment plan in the Deploy page of the project.
Note: All integration flows are shipped as part of a single accelerator project (.car) file.
