Known Issues
The issues known at the time of this release are.
- Uppercase Terms Interpreted as Product or Integration Names: Query terms entered entirely in uppercase are interpreted as Oracle product or integration names, which may lead to unintended results.
- Integration Aliases May Produce Different Responses: Responses may vary when different aliases are used for the same integration (example, CCS-OFS and C2M-OFS). For best results, use the official integration name.
- Direct Documentation URL Requests Not Supported: The assistant does not support returning direct documentation URLs or hyperlinks when explicitly requested.
- Cross-Version Queries Not Supported: Queries involving multiple product or integration versions are not supported. Please limit queries to a single product version.
- Limited Conversational Context Support: Multi-turn conversational context is not fully supported. For ambiguous follow-up queries, users may need to explicitly specify the intended product or integration.
- Responses to Contradictory Queries: For queries that contradict the information available in the supported documentation, responses may not always be grounded in the documented content.
- Flowchart Formatting in PDF Export: Flowcharts generated by the assistant may not retain consistent formatting when exported to PDF. This is a presentation-only limitation and does not affect the underlying content.
- Intermittent Service Unavailability: The assistant may occasionally encounter service issues that prevents further interaction in the current chat session. If this occurs, users can resume their work by starting a New Chat.
