Information Lifecycle Management Go-Live Checklist
The following items are things to consider as your implementation prepares for go-live:
  • Refer to Information Lifecycle Management in the Oracle Utilities Cloud Services Live Operations Guide for details regarding batch processing used with information lifecycle management.
  • The data conversion process has set the ILM_DT and ILM_ARCHIVE_SW as 'Y' for historical data. Please make sure that the PMAX partition is empty after the data conversion is completed.
  • Make sure that all historical partitions including Measurement objects (D1- MSRMT and D1-MSRMT-Log, we do sorting based on MC_ID during compression for better application performance) are in HCC.
  • Drop partition batch processing can be used to drop empty partitions as/if needed to save on database storage.
  • Scheduler batch streams are configured to run ILM crawler and non-measurement compression batch jobs on monthly basis.
