Security Setup
Before the process automation tool can be used, the security credentials of the Message Senders, used by the process automation tool, must be updated.
In order to execute the security setup, navigate using Admin > Implementation Tools > Process Automation Security Setup.
The setup script will ask you to provide a User ID, a Password and to indicate whether or not to override the existing security setup.
Please contact your system or security administrator for more information about what User ID should be used for this setup.
You should select to override existing security setup when you need to update the User ID or the Password on the existing Messages Senders, used by the process automation tool. A common use case will be mandatory periodic password rotation for the user account that was selected for the setup.
At the end of the process, you will be asked to flush all the system cache. This is required in order for the information update to take effect.
