Customization Tools Summary
While most of each cloud service application's customization options are supported, some are not and others may be limited in certain areas. The table below outlines configuration options and their availability when implementing Oracle Utilities cloud services.
| Category | Option | Supported? | Comment |
| Business Entities | Add custom business objects for product maintenance objects. | Yes | Assuming the Maintenance Object supports Business Object functionality. |
| Extend a product business object's structure and rules. | Yes | See the Algorithm Types and Algorithms section for more information. | |
| Add custom maintenance objects. | No | Creation of new tables is not supported. See the Database Accesssection for more information. Use of the SDK tool to generate Java artifacts is not supported. See the Algorithm Types and Algorithms section for more information. Refer to Migrating Legacy Custom Tables and Java to Oracle Utilities Cloud Services for more information. | |
| User Interface | Add a custom portal. | Yes | |
| Extend a product portal with custom zones. | Yes | ||
| Extend a product multi-query search with custom query options. | Yes | ||
| Customize a product menu. This includes adding new custom menu lines, hiding and reordering lines. | Yes | ||
| Add custom indexes to support custom queries | No | This is not supported, however in some special situations, customers can request this by submitting a service request (SR). Please note that this requires proper justification and exceptions can only be made if found justified. | |
| Batch processes | Add a custom batch process. | Yes | The program cannot be written in Java. See the Creating Batch Processes section for more information. The process may only access designated locations in Object Storage. See the File Access - Cloud Object Storage section for more information. |
| Web Services | Add custom inbound and outbound web services. | Yes | Use Outbound Messaging and Inbound Web Services. The services cannot rely on XSL transformations to occur in the cloud. See the File Access - Cloud Object Storage section for more information. |
| Reports | Add stored procedures to support custom reports. | No | See the Database Access section for more information. |
| Run the high volume extract reports like Bill Print via Analytics Publisher. | No | See the Oracle Utilities Cloud Services Frequently Asked Questions Guide for more information. | |
| Load and extract data from external data sources (such as xml data models, and so on), and/or write to Oracle Cloud Object Storage. | No | Analytics Publisher can only access the primary database that is provisioned with the associated cloud service (such as CCS, MSCS, WACS, BCS, and so on). |
