Data Upload Orchestration
The SQL Loader is running in multiple threads and therefore it is not performing table truncation before loading (command APPEND). Hence, the target tables should be truncated prior to the load. For better performance the indexes have to be disabled before the load and re-enabled/statistics updated after the load. The batch jobs can be organized into various chain structures, as shown in the examples below.
Single Table Upload
Figure 16-1 Single Table Upload
Diagram illustrating upload orchestration for a single table
Multiple Table or Maintenance Object Upload
Figure 16-2 Multiple Table or Maintenance Object Upload
Diagram illustrating upload orchestration for multiple tables or maintenance objects
There are multiple strategies to orchestrate the entire conversion run and to build the optimal sequence of the conversion processes. Below are some of the many possibilities:
  • Upload all legacy data extract files simultaneously, then run the subsequent validation and transformation processes for the converted object in a certain order of precedence, to preserve referential integrity
  • Begin the upload of very large tables in advance, so all upload is finished simultaneously, then validate & transform
  • Include legacy data upload batch(es) in the batch job chain for the target object
  • Upload some of the data by maintenance object, some table by table
  • Process maintenance objects end-to-end simultaneously, if there are no inter- dependencies
Full Conversion Chain per MO, Parallel Run
Figure 16-3 Full Conversion Chain per MO, Parallel Run
Diagram illustrating upload orchestration for chains of maintenance objects running in parallel
Upload All + Subsequent Validate/Transform MOs
Figure 16-4 Upload All + Subsequent Validate/Transform MOs
Diagram illustrating upload orchestration for uploading all tables and performing validation and transformation
