Information Lifecycle Management Go-Live Checklist
The following items are things to consider as your implementation prepares for go-live:
- Refer to Information Lifecycle Management in the Oracle Utilities Cloud Services Live Operations Guide for details regarding batch processing used with information lifecycle management.
- The data conversion process has set the ILM_DT and ILM_ARCHIVE_SW as 'Y' for historical data. Please make sure that the PMAX partition is empty after the data conversion is completed.
- Make sure that all historical partitions excluding Measurement objects (D1- MSRMT and D1-MSRMT-Log, we do sorting based on MC_ID during compression for better application performance) should be in HCC.
- Cut-over activities may include measurement compression batch processing which will compress Historical Measurement (D1-MSRMT and D1-MSRMT- Log) partitions during cut-over period.
- Drop partition batch processing can be used to drop empty partitions as/if needed to save on database storage.
- Scheduler batch streams are configured to run ILM crawler and compression batch jobs on monthly basis.
