Low / Very Low
If the reading's consumption is less than the low limit consumption, compute the low percentage =
((Low limit consumption - Reading's consumption) / Low limit consumption) * 100, round to the nearest integer.
If the low percentage is less than or equal to the input VERY-LOW-PERCENTAGE-CUTOFF, the reading is considered "very low", otherwise it is considered "low".
Parent topic: TD-HILO - To Do for Meter Read High/Low Errors
