Hiding Actions on the Linked Contacts Drawer
You can use VB Studio to hide delivered actions that appear in the Actions menu on the Linked contacts drawer, which you can access from Account 360. This screen is available in CX for Utilities Sales.
This image shows an example of the action menu options.
This example assumes that the reader is familiar with Account 360 and understands how to use Visual Builder. For additional information, see:
Example: Hiding an Action Menu Item on the Linked Contacts Drawer
  1. Log into CX for Utilities Sales as an administrator and navigate to Account 360.
  2. Search for and select a billing account.
  3. Click the menu at the top right of the page and select Edit Page in Visual Builder Studio.
  4. Select your workspace and click Select. Note that you can also create a new workspace if needed.
  5. In the App UIs panel, expand Customer Experience (CX), then expand Customer Experience For Utilities and then expand fragments.
  6. Select the linked-contacts fragment.
  7. Select the Variables sub-tab to display the constants and variables.
  8. Click on the USER_ACTION_CTRL_MENU_ACTIONS constant.
  9. On the right side of the screen, enter the following sample code in the Default Value field, which will disable the action:
    [{"id":"ACTION_UPDATE_BILLING_PREF","active":false}]
    Existing actions include:
    • ACTION_UPDATE_BILLING_PREF
    • ACTION_UPDATE_COMM_PREF
    • ACTION_UNLINK_CONTACT
  10. Preview your changes to verify that they look as you expected. This will launch a new tab with the Account 360 in the billing account summary view. Validate that your new option is available, and that it navigates to the appropriate URL.
  11. When your changes are ready for use, complete the steps to publish your changes to your production environment.
