Person Data Sync Configurations
The table below provides the business configurations available for attributes that can be mapped for the Fusion Contact (individual) or Account (business) synchronization to Persons in the Oracle Utilities system.
Person Data Sync Configurations for communicationType include new fields, iconClass, contactPointPurposeField and contactPointValueField, that require mapping. The iconClass refers to class of the icon that can be used in the interface for the communication type. The contactPointPurposeField and contactPointValueField both map to the Fusion application API field for the associated communication type, and are used to retrieve the corresponding contact purpose data and contact point value.
| Person Data | Configuration | Comment |
Name: PHONE_purpose Description: Holds the mapping of lookup values for the CONTACT_PURPOSE type. |
Example: "ccsValue": "WORKPHONE", "faValue": "WORK" "ccsValue": "FAXPHONE", "faValue": "FAX" |
This refers to the contact purpose specific to the PHONE contact type. You might not have the same contact purpose names configured in both systems. Be aware that in Oracle Utilities systems, FAX is a contact routing type that needs at least one value set as the primary value. In Fusion applications, FAX is a purpose field under Communication Type = Phone. The Communication Type needs at least one primary value in Fusion applications as well. To handle this mismatch, set up Fax as a custom communication method in your Oracle Utilities system to mimic the Fusion application setup so the sync will be successful. If you have different contact purpose names configured in Fusion applications and your Oracle Utilities system, update the mapping between Fusion applications and your Oracle Utilities system purpose name, and store it under the PHONE_purpose configuration in utilityConfigurations API, as FAX is considered to be a type of phone number. Additionally, be aware of the following:
Name: EMAIL_purpose Description: Holds the lookup values for the CONTACT_PURPOSE type. |
Example: "ccsValue": "PRIMARYEMAIL", "faValue": "PERSONAL" |
This refers to the contact purpose specific to the EMAIL contact type. You might not have the same contact purpose names configured in both systems.
Note: It is recommended to retain the PERSONAL email type in the Utility Configuration, and ensure a corresponding mapping is created in your CIS. This is needed because if no email purpose is explicitly provided, it defaults to PERSONAL. To ensure this defaulted data syncs to your CIS without issues, the PERSONAL type must be recognized and mapped appropriately. For example: |
Name: WEB_purpose Description: Holds the mapping of lookup values for the CONTACT_PURPOSE type. |
Example: "ccsValue": "WEB", "faValue": "PERSONAL" |
This refers to the contact purpose specific to the WEB contact type. You might not have the same contact purpose names configured in both systems. |
Parent topic: View and Edit the Existing Configuration
