7 Exporting Data
Many account managers need to create reports to analyze data, or provide printed information to their managers or customers. To facilitate these tasks, account managers can export data from multiple places within the Customer Experience for Utilities Sales solution.
Data that can be exported is noted with an Export button or icon. When you click the button or icon, you can select the export format for your data. The available options vary, depending on the data you are exporting, but can include:
- Excel
- CSV
After you select an option, the system displays the Export started message. You can continue working as the export process runs in the background.
Be aware that system administrators can restrict the number of rows that can be exported to manage performance. If your data set exceeds the configured threshold, the system displays a message indicating how many rows of the data set were exported.
