Menu Option | Name Used in Documentation | Customer Install Value |
Environment ID | ENVIRONMENT_ID | |
Server Roles | SERVER_ROLES | |
Oracle Client Home Directory | ORACLE_CLIENT_HOME | |
Web Java Home Directory | JAVA_HOME | |
**ONS JAR Directory | ONS_JAR_DIR | |
Web Application Server Home Directory | WEB_SERVER_HOME | |
***Additional JAR Directory | WLTHINT3CLIENT_JAR_DIR |
Import Keystore Directory | KS_IMPORT_KEYSTORE_FOLDER |
Environment Mount Point | SPLDIR | |
Log File Mount Point | SPLDIROUT | |
Environment Name | SPLENVIRON | |
Install Application Javadocs | WEB_ISJAVADOCS | |
Install Sample CM Source Code | CM_INSTALL_SAMPLE |
Environment Description | DESC |
Business Server Host | BSN_WLHOST | |
Business Server Application Name | BSN_APP |
Web Server Host | WEB_WLHOST | |
Weblogic SSL Port Number | WEB_WLSSLPORT | |
Weblogic Console Port Number | WLS_ADMIN_PORT | |
Web Context Root | WEB_CONTEXT_ROOT | |
WebLogic JNDI User ID | WEB_WLSYSUSER | |
WebLogic JNDI Password | WEB_WLSYSPASS | |
WebLogic Server Name | WEB_WLS_SVRNAME | |
Web Server Application Name | WEB_APP | |
This Is A Production Env. And The Client Is Live | WEB_ISLIVEPRODUCTION | |
Deploy Javadocs Module | WEB_DEPLOY_JAVADOCS | |
Enable The Unsecured Health Check Service | WEB_ENABLE_HEALTHCHECK | |
MDB RunAs User ID | WEB_IWS_MDB_RUNAS_USER | |
Super User Ids | WEB_IWS_SUPER_USERS |
Application Server Database User ID | DBUSER | |
Application Server Database Password | DBPASS | |
Batch Database User ID | BATCH_DBUSER | |
Batch Database Password | BATCH_DBPASS | |
Web JDBC DataSource Name | JDBC_NAME | |
Database Name | DBNAME | |
Database Server | DBSERVER | |
Database Port | DBPORT | |
ONS Server Configuration | ONSCONFIG | |
Database Override Connection String | DB_OVERRIDE_CONNECTION | |
Character Based Database | CHAR_BASED_DB | |
Oracle Client Character Set NLS_LANG | NLS_LANG |
Batch RMI Port | BATCH_RMI_PORT | |
RMI Port number for JMX Business | BSN_JMX_RMI_PORT_PERFORMANCE | |
RMI Port number for JMX Web | WEB_JMX_RMI_PORT_PERFORMANCE | |
JMX Enablement System User ID | BSN_JMX_SYSUSER | |
JMX Enablement System Password | BSN_JMX_SYSPASS | |
Coherence Cluster Name | COHERENCE_CLUSTER_NAME | |
Coherence Cluster Address | COHERENCE_CLUSTER_ADDRESS | |
Coherence Cluster Port | COHERENCE_CLUSTER_PORT | |
Coherence Cluster Mode | COHERENCE_CLUSTER_MODE |
Import TrustStore Directory | TS_IMPORT_KEYSTORE_FOLDER |
OSB Home | OSB_HOME | |
OSB Host Server | OSB_HOST | |
OSB Port Number | OSB_PORT_NUMBER | |
OSB SSL Port Number | OSB_SSL_PORT | |
OSB Managed Server Port Number | ||
OSB Managed Server SSL Port Number | OSB_MANAGED_SSL_PORT | |
JDBC URL for Database | DBURL_OSB | |
OSB Service Table Schema Name | RCUSTBSCHEMA_OSB | |
OSB Service Table Schema Password | RCUSTBSCHEMAPWD_OSB | |
OSB WebLogic User Name | WEBLOGIC_USERNAME_OSB | |
OSB WebLogic User Password | WEBLOGIC_PASSWORD_OSB | |
Mount Point for OSB Files | OSB_LOG_DIR | /spl/sploutput/osb |
SOA Home | SOA_HOME | |
SOA Host Server | SOA_HOST | |
SOA Port Number | SOA_PORT_NUMBER | |
SOA SSL Port Number | SOA_SSL_PORT_NUMBER | |
SOA Internal URL | SOA_INTERNAL_URL | |
SOA External URL | SOA_EXTERNAL_URL | |
JDBC URL for SOA Database | ||
SOA Service Table Schema Name | RCUSTBSCHEMA_SOA | |
SOA Service Table Schema Password | RCUSTBSCHEMAPWD_SOA | |
SOA WebLogic User Name | WEBLOGIC_USERNAME_SOA | |
SOA WebLogic User Password | WEBLOGIC_PASSWORD_SOA | |
Specify the Path for XAI/IWS Service | WEB_SERVICE_PATH | XAIApp/xaiservert |
MDM Bulk Request Callback URL | ||
MDM Headend HTTP Connection Timeout | 50000 | |
MDM Headend HTTP Read Timeout | 500000 | |
MDM SOA Request Queue JNDI Name | queue/BulkRequestQueue | |
MDM SOA Notify Queue JNDI Name | queue/BulkNotifyQueue | |
MDM SOA Command Queue JNDI Name | queue/BulkCommandQueue | |
SGG-NMS TestHarness Partition Name | SGG-NMS_Test |
JNDI Name of Destination Queue to publish SGG payloads for DataRaker Integration Tool | DataRakerQueue | |
Number of records (SGG Payloads) to accumulate | 100 | |
Max file size for the accumulated (SGG Payloads) file in Kilobytes | 524288 | |
Specify a time which, when exceeded, causes a new outgoing file to be created in seconds | 600 | |
Polling frequency of Staging directory for new files in seconds | 60 | |
Mount point/directory for the accumulated SGG payload file | /spl/sploutput/staging | |
Mount Point/directory for the converted XML file to place for DataRaker | /spl/sploutput/int |
LG SOA Partition Name | LG | |
LG SOA TestHarness Partition Name | LG_Test | |
AMI Event Subscriber Output Path | /spl/sploutput/osb/lg-cim-event | |
MR_Server endpoint URI | ||
CD_Server endpoint URI | ||
CIM_Server endpoint URI | ||
MeteringServer endpoint URI | ||
Security policy attached to outbound web service calls to a CIM interface | sgg/d3_cfs_cim_header_client_policy | |
Security policy attached to inbound web service calls from a CIM interface | sgg/d3_cim_token_service_policy | |
The name of the OWSM policy to use when SOA calls a head end system | oracle/http_basic_auth_over_ssl_client_policy | |
The name of the OWSM policy to use when SOA is called by a head end system | oracle/http_basic_auth_over_ssl_service_policy |
NES endpoint URI | ||
SOA partition to which the application is installed | Echelon | |
Path to the NES EventManager web service on the head end system | CoreServices/EventManager.asmx | |
Path to the NES GatewayManager web service | CoreServices/GatewayManager.asmx | |
Path to the NES DeviceManager web service on the head end system | CoreServices/DeviceManager.asmx | |
Path to the NES SettingManager web service on the head end system | CoreServices/SettingManager.asmx | |
Path to the NES UserManager web service on the head end system | CoreServices/UserManager.asmx | |
Name of the OWSM policy to use when SOA calls a head end system | oracle/http_basic_auth_over_ssl_client_policy | |
Name of the OWSM policy to use when SOA is called by a head end system | oracle/http_basic_auth_over_ssl_service_policy |
Sensus SOA TestHarness Partition Name | Sensus_Test | |
Sensus SOA Partition Name | Sensus | |
MR Server Endpoint URI | ||
CD Server Endpoint URI | ||
OD Server Endpoint URI | ||
Headend Http Read Timeout | 500000 | |
Headend Http Connection Timeout | 50000 | |
SSN SOA Partition Name | SSN | |
SOA Weblogic User Name | ||
SSN SOA Queue JNDI Name | queue/SSNODRQ | |
SSN Headend DataAggregation Endpoint URI | ||
The URL for the SSN 4.7 DataAggregation service (DataAggregation.asmx) | http://127.0.0.1/CoreServices/DataAggregation.asmx | |
The URL for the SSN 4.10 DataAggregation service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DataAggregat... | |
The URL for the SSN 4.14 DataAggregation service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_5_1/DataAggregationPort | |
URL for the SSN 5.1/2.7 DataAggregation service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DataAggregationPort | |
URL for the SSN 5.1/2.8DataAggregation service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_8/DataAggregationPort | |
SSN Headend DeviceManager Endpoint URI | ||
URL for the SSN 4.7 DeviceManager service (DeviceManager.asmx) | http://127.0.0.1/CoreServices/DeviceManager.asmx | |
URL for the SSN 4.10 DeviceManager service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceManage... | |
URL for the SSN 5.1/2.7 DeviceManager service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceManagerPort | |
URL for the SSN 5.1/2.8 DeviceManager service | https://ssn.ssnsgs.net:3000/amm/ webservice/v2_8/DeviceManagerPort | |
SSN Headend DeviceResults Endpoint URI | http://127.0.0.1/CoreServices/ DeviceResults.asmx | |
URL for the SSN 4.7 DeviceResults service (DeviceResults.asmx) | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceResult... | |
The URL for the SSN 4.10 DeviceResults service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceResults | |
The URL for the SSN 5.1/2.7 DeviceResults service | https://ssn.ssnsgs.net:3000/amm/ webservice/v2_7/DeviceResults | |
The URL for the SSN 5.1/2.8 DeviceResults service | https://ssn.ssnsgs.net:3000/amm/ webservice/v2_8/DeviceResults | |
SSN Headend JobManager Endpoint URI | ||
The URL for the SSN 4.7 JobManager service (JobManager.asmx) | http://127.0.0.1/CoreServices/JobManager.asmx | |
The URL for the SSN 4.10 JobManager service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/JobManagerPort | |
The URL for the SSN 5.1/2.7 JobManager service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/JobManagerPort | |
The URL for the SSN 5.1/2.8 JobManager service | ||
SSN Bridge Destination Name | SSNTestHarnessBridgeDestination | |
SSN Bridge Destination Additional Classpath | ||
SSN Bridge Destination Connection URL | ||
SSN Bridge Destination Initial Context Factory | weblogic.jndi.WLInitialContextFactory | |
SSN Bridge Connection Factory JNDI Name | jms/SSNTestHarnessConnectionFactory | |
SSN Bridge Destination Queue JNDI Name | queue/SSNTestSSNODRQ | |
SSN Destination Bridge Username |
DG SOA Partition Name | DG | |
DG SOA TestHarness Partition Name | DG_Test |
Itron SOA Partition Name | Itron | |
DataSubscriberService Output Path | ||
ExceptionSubscriberService Output Path | ||
Itron Headend DataService Endpoint URI | ||
Itron Headend DiagnosticService Endpoint URI | ||
Itron Headend UtilService Endpoint URI | ||
Itron Headend ControlService Endpoint URI | ||
Itron Headend ProvisioningService Endpoint URI | ||
Itron Headend ProvisioningService370 Endpoint URI | ||
Itron Headend ControlService370 Endpoint URI: | ||
Itron SOA TestHarness Partition Name | Itron_Test | |
Menu Option | Name Used in Documentation | Customer Value Install |
OUAF DBMS Scheduler User | OUAF_DBMS_SCHEDULER_USER | |
WebLogic ThreadPoolWorker Enabled | WLS_THEADPOOLWORKERENABLED | |
Online JVM Batch Server Enabled | BATCHENABLED | |
Online JVM Batch Number of Threads | BATCHTHREADS | |
Online JVM Batch Scheduler Daemon Enabled | BATCHDAEMON | |
Enable Batch Edit Functionality | BATCHEDIT_ENABLED | |
Batch Online Log Directory | BATCH_ONLINE_LOG_DIR | |
JDBC Read Timeout | JDBC_TIMEOUT | |
Enable JMS Global Flush for Batch | ENABLE_JMS_GLOBAL_FLUSH | |
Add UsernameToken.xml | ADD_USERNAMETOKEN_XML | |
IWS deployment target | WLS_CLUSTER_NAME | |
Web Admin Server Host | WEB_ADMIN_SERVER | |
Split File Size in MB | TEMPSTORAGE_SPLITFILESIZE | |
GIS Service Running on the same Web Server | GIS | |
GIS Service URL | GIS_URL | |
GIS WebLogic System User ID | GIS_WLSYSUSER | |
GIS WebLogic System Password | GIS_WLSYSPASS | |
Online Display Software Home | ONLINE_DISPLAY_HOME | |
Max Queries To Hold In Cache Across All Threads | XQUERIES_TO_CACHE | |
Seconds Timeout Flush Cache Completely | XQUERY_CACHE_FLUSH_TIMEOUT | |
Malware Scan Host | MALWARE_SCAN_HOST | |
Malware Scan Port | MALWARE_SCAN_PORT | |
Malware Scan Timeout (Seconds) | MALWARE_SCAN_TIMEOUT |
Global JVM Arguments | GLOBAL_JVMARGS | |
Ant Min Heap Size | ANT_OPT_MIN | |
Ant Max Heap Size | ANT_OPT_MAX | |
Ant Additional Options | ANT_ADDITIONAL_OPT | |
Thread Pool Worker Java Min Heap Size | BATCH_MEMORY_OPT_MIN | |
Thread Pool Worker Java Max Heap Size | BATCH_MEMORY_OPT_MAX | |
Thread Pool Worker Additional Options | BATCH_MEMORY_ ADDITIONAL_OPT |
HTTP Allowed Methods | HTTP_ALLOWED_METHODS | |
Web Application Cache Settings | WEB_L2_CACHE_MODE | |
Web Server Port Number | WEB_WLPORT | |
CSRF Protection For REST Services | CSRF_PROTECTION | |
OWSM Protection For REST Services | OWSM_PROTECTION_FOR_REST_SERVICES | |
Domain Home Location | WLS_DOMAIN_HOME | |
Batch Cluster URL | WEB_BATCH_CLUSTER_URL | |
Strip HTML Comments | STRIP_HTML_COMMENTS | |
Authentication Login Page Type | WEB_WLAUTHMETHOD | |
Web Form Login Page | WEB_FORM_LOGIN_PAGE | |
Web Form Login Error Page | WEB_FORM_LOGIN_ERROR_PAGE | |
Javadocs Login Page | WEB_JAVADOCS_FORM_LOGIN_PAGE | |
Javadocs Form Login Error Page | WEB_JAVADOCS_FORM_LOGIN_ERROR_PAGE | |
Web Security Role | WEB_ROLE_NAME | |
Web Principal Name | WEB_PRINCIPAL_NAME | |
Javadocs Security Role | WEB_JAVADOCS_ROLE_NAME | |
Javadocs Principal Name | WEB_JAVADOCS_PRINCIPAL_NAME | |
Use development Configuration | WEB_ISDEVELOPMENT | |
Preload All Pages on Startup | WEB_PRELOADALL | |
Maximum Tolerable Preload Errors | WEB_PRELOAD_ERROR_COUNT | |
Maximum Age of a Cache Entry for Text | WEB_MAXAGE | |
Maximum Age of a Cache Entry for Images | WEB_MAXAGEI | |
JSP Recompile Interval (s) | WEB_WLPAGECHECKSECONDS | |
Enable Strict Transport Security | ||
Strict Transport Security Max Age | HSTS_MAX_AGE | |
Strict Transport Security Include Subdomains | HSTS_SUBDOMAINS | |
Strict Transport Security Preload | HSTS_PRELOAD | |
Oracle Guided Learning Id | ORACLE_GUIDED_LEARNING_ID | |
Cookie Path Restriction | COOKIE_PATH_RESTRICTION | |
Enable host header request validation | ENABLE_HOST_HEADER_CHECK | |
List of valid host names for HTTP header request | VALID_HOST_NAMES | |
Valid domain for host header check | DOMAIN_NAME |
Diagnostic Context Enabled | WLS_DIAGNOSTIC_CONTEXT_ENABLED |
Enable CORS For Embedded UI | ENABLE_CORS | |
Allowed Frame Ancestors Max Number | CORS_ALLOWED_FRAME_ANCESTORS_MAX_NUMBER | |
URI For Variable CSP_FRAME_ANS_HOST1 | CORS_CSP_FRAME_ANS_HOST1 | |
URI For Variable CSP_FRAME_ANS_HOST2 | CORS_CSP_FRAME_ANS_HOST2 | |
Custom URL For CSP img-src | CSP_URL_IMG_SRC | |
Custom URL For CSP script-src | CSP_URL_SCRIPT_SRC | |
Custom URL For CSP style-src | CSP_STYLE_SRC | |
Custom URL For CSP font-src | CSP_FONT_SRC | |
Custom URL For CSP connect-src | CSP_CONNECT_SRC | |
Custom URL For CSP frame-src | CSP_URL_FRAME_SRC | |
Custom URL For CSP form-action | CSP_FORM_ACTION_SRC | |
URI For Variable FA_DOMAIN | CORS_FA_DOMAIN | |
URI For Variable ALM_DOMAIN | CORS_ALM_DOMAIN | |
Restriction URLs Enable | CLOUD_RESTRICTION_URLS_ENABLE | |
Custom SQL Security | CUSTOM_SQL_SECURITY | |
White List Full Path | CLOUD_WHITE_LIST_PATH | |
Custom White List Full Path | CLOUD_CUSTOM_WHITE_LIST_PATH | |
Substitution Variable List File Location | CLOUD_SUBSTITUTION_VARIABLE_LIST_FILE_LOCATION | |
Directory For Variable F1_CMA_FILES | CLOUD_LOCATION_F1_MIGR_ASSISTANT_FILES | |
URI For Variable F1_OAUTH2_URI | CLOUD_LOCATION_F1_OAUTH2_URI | |
URI for Variable F1_BASE_REST_URL | CLOUD_LOCATION_F1_BASE_REST_URL | |
URI for Variable F1_OPEN_API_BASE_URL | CLOUD_LOCATION_F1_OPEN_API_BASE_URL | |
URI For Variable F1_BASE_WEB_URI | CLOUD_LOCATION_F1_BASE_WEB_URI | |
URI For Variable F1_BASE_IWS_URI | CLOUD_LOCATION_F1_BASE_IWS_URI | |
Consolidated Logfile Full Path | CONSOLIDATED_LOG_FILE_PATH | |
Temporary File Location | TMP_FILE_LOCATION |
Enable/Disable REST Service For The JMX | JMX_REST_SERVICE_FLAG | |
Hostname To Run The REST Server | JMX_REST_SERVICE_HOST | |
Batch Port For REST Server | JMX_REST_PORT_BATCH | |
Web Port For REST Server | JMX_REST_PORT_WEB | |
Business Server Port For REST Server | JMX_REST_PORT_SERVICE | |
Server Context | JMX_REST_CONTEXT | |
SSL Flag | JMX_HTTPSSL_FLAG | |
Keystore File Path | JMX_HTTPSSL_KEYSTORE_FILE | |
Keystore Type | JMX_HTTPSSL_KEYSTORE_TYPE | |
Keystore Passphrase | JMX_HTTPSSL_KEYSTORE_PASSPHRASE | |
Keypair Passphrase | JMX_HTTPSSL_KEYPAIR_PASSPHRASE | |
Trust Store File Path | JMX_HTTPSSL_TRUSTSTORE_FILE | |
Truststore Type | JMX_HTTPSSL_TRUSTSTORE_TYPE | |
Truststore Passphrase | JMX_HTTPSSL_TRUSTSTORE_PASSPHRASE | |
Http Server Username For Authentication | JMX_HTTP_REST_USERNAME | |
Http Server Password For Authentication | JMX_HTTP_REST_PASSWORD |
enable multispeak30 protocol | ENABLE_MULTISPEAK30 | |
enable multispeak41 protocol | ENABLE_MULTISPEAK41 | |
enable cim12 protocol | ENABLE_CIM12 | |
enable cim20 protocol | ENABLE_CIM20 |
Enable OSB SSL Port | false | |
OSB Trust Keystore Type | Demo | |
OSB Trust Keystore File Type | JKS | |
OSB Trust Keystore File |
SOA Initial Heap Size | 1024 | |
SOA Maximum Heap Size | 2048 | |
SOA Minimum Perm Size | 512 | |
SOA Maximum Perm Size | 1024 | |
SOA Application Additional Options | ||
The name of the OWSM policy to use when SOA calls another SOA service | oracle/http_basic_auth_over_ssl_client_ policy | |
The name of the OWSM policy to use when SOA is called by another SOA service | oracle/http_basic_auth_over_ssl_service_ policy | |
The name of the OWSM policy to use when SOA calls an OUAF service | oracle/wss_http_token_over_ssl_client_ policy |
OSB Initial Heap Size | 512 | |
OSB Maximum Heap Size | 1024 | |
OSB Minimum Perm Size | 512 | |
OSB Maximum Perm Size | 1024 | |
OSB Application Additional Options |
Enable Data Migration | FALSE | |
Data Migration Database User | ||
Data Migration Database Password |
Enable SOA SSL Port | false | |
SOA Trust Keystore Type | Demo | |
SOA Trust Keystore File Type | JKS | |
SOA Trust Keystore File |
SSN TestHarness SOA Host Server | slc11cds.us.oracle.com | |
SSN TestHarness SOA Port Number | 8920 | |
SSN SOA TestHarness Partition Name | SSN_Test | |
SSN SOA TestHarness Queue JNDI Name | queue/SSNTestSSNODRQ |
