Create a Dimension Alias
Dimension alias are alias names on the warehouse dimension tables. You can specify the alias names for the Dimension type augmentations and the data that's in the warehouse already as dimensions. The alias names enable you to reuse the existing warehouse tables with different names in the subject areas.
For more information, see Create a Dimension Alias in the Fusion Data Intelligence documentation.
