Deploy Your Oracle Utilities Data Intelligence Release Bundle
Bundles are snapshots of application artifacts such as configurations and customizations at a certain point in time. The Global Bundle Repository is an app-store like experience for users to import bundles created by Oracle, partners, or other users.
When you deploy the Oracle Utilities Data Intelligence bundle, you gain access to the prebuilt subject areas, metrics, dashboards, and reports from the source application.
Before you deploy an Oracle Utilities Data Intelligence release bundle, determine whether you are performing an initial installation or upgrading from an existing OUDI deployment, and complete the prerequisite steps for your scenario.
Initial Installation Scenario: Create the Oracle Utilities Data Intelligence instance, create the source application connections, test each connection, refresh metadata for each successful connection, set up pipeline parameters, and complete the one-time data augmentation job for each applicable connector.
Upgrade Scenario: Test each existing source application connection and refresh metadata for each successful connection.
Import the Utilities Bundles
  1. Sign in to your service.
  2. In the Oracle Utilities Data Intelligence Admin Console, click Bundle Repository under Application Administration.
  3. On the Global Bundle Repository page, click the Bundle repository tab.
  4. Look for and select one or more bundles titled ‘OU <Type> Analytics', where <Type> refers to the type of analytics you have purchased. For example, you might see bundles for 'OU Customer Analytics' or 'OU Device Analytics'.
  5. Click Import.
  6. In the dialog that displays, select the checkbox to agree to the terms and conditions, and click Submit.
The bundle appears as Scheduled in the Activity tab. You can refresh the page to view the latest status. When it is finished importing, it is displayed as Completed.
Deploy the Oracle Utilities Bundles
You deploy the Oracle Utilities bundles after you import them from the Global Bundle Repository. Any bundles you have imported appear in the Local Bundles tab of the Global Bundle Repository.
  1. Contact Oracle Utilities Data Intelligence Support and ask what date and time the bundles can be deployed. This way you ensure that the bundles are deployed at a time when data will be available from the source application.
  2. Sign in to your service.
  3. In the Oracle Utilities Data Intelligence Admin Console, click Bundle Repository under Application Administration.
  4. On the Global Bundle Repository page, click the Local Bundles tab.
  5. Locate the bundle you want to deploy.
  6. Click the actions menu (...) and select Deploy.
  7. In the Deploy Bundles dialog, click Select Date and Time. Enter the date and time you received from the Oracle Utilities support team.
  8. Click Deploy.
