Refresh Oracle Utilities Data Intelligence Data
A full data refresh reloads data from your source applications into Oracle Utilities Data Intelligence. You might need a full refresh when the data in Oracle Utilities Data Intelligence must be resynchronized with the source data, such as after a data issue or another condition that requires the existing data to be reloaded.
To perform a full data refresh, you first disable the incremental data pipeline and submit a service request for Oracle to complete the required internal refresh. After Oracle confirms that the internal refresh is complete, you reset and reload the applicable data sources, and then restore the incremental refresh schedule.
Disable the Incremental Data Pipeline
Disable your scheduled incremental refresh before Oracle begins the internal refresh work.
To disable the incremental data pipeline:
- Sign in to Oracle Utilities Data Intelligence.
- In the Oracle Utilities Data Intelligence Admin Console, under Application Administration, select Data Configuration.
- From the Data Source menu, select the applicable connector, such as Oracle Utilities Customer Data.
- Open Pipeline Settings for the selected data source.
- On the Pipeline Settings page, make a note of the information displayed under Data Refresh Schedule in the Interval menu, as you will re-enable this later.
- Set Interval to None.
Request a Full Data Refresh
Request a full data refresh from Oracle Utilities Data Intelligence Support.
To request a full data refresh:
- Sign in to My Oracle Support.
- Submit a service request to Oracle Utilities Data Intelligence Support and request a full data refresh.
- In the service request, state that you have disabled the incremental data pipeline.
- Wait until Oracle Utilities Data Intelligence Support confirms in the service request that the internal refresh is complete. Reset and reload the data sources only after you receive this confirmation.
Reset and Reload the Data Source
After Oracle Utilities confirms in the service request that the internal refresh is complete, reset and reload the applicable data sources.
To reset and reload the data source:
Monitor the Reset and Reload Request
Monitor the reset and reload request until it completes.
To monitor the reset and reload request:
- On the Data Configuration page, under Activity History, select Request History.
- On the Request History page, select the One Time tab.
- Locate the request that you submitted to reset and reload the data sources.
- Confirm that the request status is Completed.
- To review request details, select the icon in the Summary column.
The reset and reload request can take a long time to complete. Other incremental or full-load requests do not start until it finishes.Re-enable the Incremental Data Pipeline
After the reset and reload request completes successfully, restore the incremental data pipeline schedule that you recorded before starting this procedure.
For detailed instructions, see Schedule Incremental Data Refreshes in the Fusion Data Intelligence documentation.
