Reset the Password for OAX_USER and Custom Schemas
Oracle Utilities Data Intelligence provides default schemas (also known as users) such as the ADMIN schema and OAX_USER schema. You can create custom schemas to meet your customization requirements.
You can change the password for the OAX_USER and custom schemas using either SQL Developer or the Oracle Cloud Infrastructure Console. For more information, see the instructions in the Fusion Data Intelligence documentation: Reset the Password for OAX_USER and Custom Schemas .
