Initial Data Export Prerequisites
Before performing the initial data export, verify the following requirements to avoid interruptions:
Database and Privileges
Verify the following prerequisites before you begin the export process.
Connection: Access to the source PDB through SQL*Plus, SQL Developer, or SQLcl. Use a service name for the PDB (such as
sqlplus username/password@PDB_SERVICE). -
User Privileges: Log in with a user granted
EXP_FULL_DATABASErole (such as a dedicated export user likeCISADM). Additional privileges needed:-
CREATE TABLEfor temporary metadata tables. -
READandWRITEon the export directory (e.g.,DATA_PUMP_DIR). -
QUERY_REWRITEandSELECT_CATALOG_ROLEfor metadata queries.
Database Version: Oracle Database 19c or higher, with Data Pump (expdp/impdp) enabled.
Space Allocation: At least 1.5 times the size of the largest export group in the
DATA_PUMP_DIRfilesystem. Monitor viaV$DATAFILEandDBA_FREE_SPACE.
Required Files
Scripts: Download from OCI object storage:
EXPORT_TABLE_LIST_GENERATION.sql: Generates the table export list. -
EXADATA_PDB_EXPORT_SCRIPT.sql: Performs the Data Pump export. -
MANIFEST_FILE_GENERATION.sql: Creates JSON manifests.
Configuration Files: Priority CSV files from ArtifactHub (uploaded by OUDI Team). These files define export groups (such as Priority 100: Critical tables; Priority 10: Auxiliary data). Customize as needed and notify DevOps for pipeline synchronization.
priority_config_ccs.csv(for CCS/C2M sources) -
priority_config_wacs.csv(for WACS/WAM sources) -
priority_config_dacs.csv(for DACS/DAM sources)
