Data Browser
The Data Browser is an interactive tool that allows customers to visualize and explore their energy use trends and costs, and make comparisons to useful benchmarks, such as weather and similar homes. One or more views for Energy Costs, Energy Use, and other types of information are available. If applicable, customers can also use menus to switch between multiple premises, service agreements, or service points.
Use the information below to review general configuration options for the Data Browser, such as which views to enable, the order of the views, and the default time view. For configurations that are specific to each view, see Energy Use View, Energy Costs View, Neighbors View, or Usage Breakdown View.
Data Browser Example
The image below is an example of the Data Browser Energy Use view.
The Data Browser energy use view, which displays a customer's historical energy use.
General Configuration Options
Use the information below to review general configuration options for the Data Browser. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Graph Display and Order
Utilities can choose which graphs or views to display, and the order in which to display them.
Default: The following views are displayed in the order listed as long as there is sufficient data: Energy Costs, Energy Use, and Neighbors.
The Usage Breakdown view is hidden by default.
Required
Choose one of the following:
  • Use the default.
  • Work with your Delivery Team to choose the views to display and the order.
Tooltip Explanation Link for Estimated Reads (not depicted)
Utilities can provide a URL to include as an explanation link for estimated reads.
Default: No link provided.
Optional
  • Use the default.
  • Provide a URL.
Default Fuel or Resource Type Selected
Utilities can choose which fuel or resource type to be selected by default.
Default: Display electric data as default.
Optional
  • Display electric data as the default.
  • Display gas data as the default.
  • Display combined fuel (electric and gas) as the default.
Combined Fuel View
For dual fuel customers with electricity and gas service, a combined fuel view combines the energy use for gas and electricity into a single "units" value. When the combined fuel view is enabled, applicable tooltips also display combined totals. The combined view also includes billing insights for a customer's energy costs.
Default: Hide the combined fuel view.
Optional
  • Use the default.
  • Display a combined fuel view.
4. Default Time View
The Bill view can be displayed by default for customers with AMI data. Customers without AMI data can only use the Year view.
Default: Display the Year view as the initial view. Customers with AMI data can then select to see the Bill view or Day view.
Optional
  • Display Year view as the default.
  • Display Bill view as the default for customers with AMI data.
Peak Time Rebates Annotation (not depicted)
Peak event days and hours are highlighted with icons and tooltips. The tooltips display details regarding the credits the customer earned by participating in a peak event.
Default: Disabled
Optional
  • Use the default.
  • Enable Peak Time Rebate Annotation.
Peak Time Rebates Annotation Learn More Link (not depicted)
Utilities can provide a URL to include as a Learn More link for Peak Time Rebates annotations.
Default: None
Optional
  • Use the default.
  • Provide a URL.
Display of Device (Meter) ID in Drop-Down Selector
The device ID (meter number) can be displayed instead of the service point ID in the drop-down selector menu of relevant widgets. Displaying the device ID can be a clearer way for customers to identify the energy use patterns associated with each of their meters.
Default: Disabled.
Optional
  • Use the default.
  • Enable the display of the device (meter) ID.
Display of Custom Meter or Service Point Names
You can add custom names to meters or service points in the widget. This lets customers define custom names for each meter or service point so they can more easily distinguish and select the appropriate one when viewing data in the widget.
Your Oracle Utilities Delivery Team must complete additional setup before this option can be enabled.
Default: Disabled.
Optional
  • Use the default.
  • Enable custom meter names.
Display of Disclaimers by Customer Type (Residential or Non-Residential)
You can show customer type-specific disclaimer text (for residential or non-residential customers) in each of the widget views. This helps utilities present more relevant explanatory information without needing to maintain separate widget instances. A general disclaimer can remain available as a fallback when a customer-specific message is not configured.
Default: No disclaimer, or a generic disclaimer if one has been configured.
Optional
  • Use the default.
  • Work with your Delivery Team to provide disclaimers for each Data Browser view based on customer type.
User Experience Variations
The user experience of this feature may vary for customers and utilities depending on their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see Data Browser in the Digital Self Service - Energy Management Cloud Services Overview.
