Home Energy Analysis Light
The Home Energy Analysis (HEA) Light widget encourages customers to complete the Home Energy Analysis survey, and can display a disaggregation of a customer's top three categories of energy use before or after the survey has been completed. HEA Light is designed to be included in the Smart Dashboard or embedded on another utility-hosted web page to promote the survey and lead customers to the full Home Energy Analysis experience.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Show the Disaggregation Before or After Survey Completion Utilities have the option to display a disaggregation in the HEA Light widget before customers take the HEA survey. Customers can still take the survey later to update their disaggregation results. Default: Show the disaggregation after survey completion. |
Choose one of the following:
User Experience Variations
The user experience of the feature may vary for customers and utilities depending upon their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see Home Energy Analysis Light in the Digital Self Service Energy Management Cloud Services Overview Guide and go to the User Experience Variations section.
