Bill Guide
The Bill Guide is a summary of billing insights that helps customers better understand their most recent billed usage charges. It includes a bill breakdown, weather insight, and neighbor comparison insight.
Bill Guide is embedded as a single widget rather than as multiple separate widgets. Utilities must be on the latest technical framework for widgets in order to embed it.
Image of bill guide dashboard
Embedding Guidelines
Widget Name: widget-bill-guide
Full Embedding Code: <opower-widget-bill-guide opower-instance="widget-bill-guide"></opower-widget-bill-guide>
  • Bill Guide is best suited for a prominent location on your website, since it presents a summary of key billing insights. It is recommended that you place it in a primary or top-level section on your website, such as the first among your tabs or pages related to energy efficiency.
  • Bill Guide contains components and insights that are suitable for embedding on the same page as other widgets. For example, Bill Guide could be embedded on a dashboard-like page above other widgets or insights related to usage and weather trends.
For more information about Bill Guide, including details about its data requirements and the overall user experience, see the Bill Guide description in the product overview.
