Green Button
The Green Button allows customers to export their billing data into CSV or XML format. It is typically located beneath the Data Browser.
Screenshot of the Data Browser with the Green Button link.
When a customer clicks the Green Button link, a Download my data section displays and allows the customer to choose between downloading their data in CSV or XML format.
Screenshot of the Green Button Download My Data section, which allows customers to download billing data. Options available for all bill totals or specific bill periods. Format options include CSV and XML.
Embedding Guidelines
Widget Name: widget-usage-export
Full Embedding Code: <opower-widget-usage-export opower-instance="widget-usage-export"></opower-widget-usage-export>
The Green Button is typically included under the Data Browser since it is natural for customers to see a connection between visualizing their data in a graph and then downloading more details about it. Consider embedding these two widgets on the same page when completing the steps in Embedding a Widget.
For more information about Green Button, including details about its data requirements and the overall user experience, see the resources below.
