7 Testing an Embedded Widget
The utility can view the embedded widgets with fixture data by appending fixtures=true as a query parameter definition in the <script> tag for any webpage that includes embedded widgets. Enabling fixtures removes the authentication process and displays the widget content with example data and configuration. This configuration applies to an entire page and thus applies to all widgets embedded on the page. This type of testing is helpful for viewing a widget in a web environment ahead of full widget configuration and authentication setup. Examples are shown below.
WARNING:
Fixture-based testing is not a replacement for more comprehensive testing procedures. It is recommended to test with a test user account available in the Oracle Utilities Opower data set, or once single sign-on setup is completed.
Stage Environment Example
<!DOCTYPE html><html>
<head>
<meta charset="utf-8" />
<meta http-equiv="X-UA-Compatible" content="IE=edge">
 <title>Page Title</title>
 <meta name="viewport" content="width=device-width, initial-scale=1">
 <script src="https://ei-util-stage.opower.com/ei/x/embedded-api/core.js?fixtures=true"></script>
</head>
<body>
 <div>
 <opower-widget-neighbor-comparison opower-instance="widget-neighbor-comparison"></opower-widget-neighbor-comparison>
 </div>
 <div>
 <opower-widget-data-browser opower-instance="widget-data-browser"></opower-widget-data-browser>
 </div>
</body>
</html>
Production Environment Example
<head>
 <script src="https://util.opower.com/ei/x/embedded-api/core.js?fixtures=true"></script>
</head>
<body>
 <div>
 </div>
 <div>
 </div>
</body>
</html>
