Tips Light
Tips Light displays the top three tip guides for the customer's household. These tip guides promote customer interest in tips and lead them to more detailed tip information.
Embedding Guidelines
Widget Name: widget-tips-light
Full Embedding Code: <opower-widget-tips-light opower-instance="widget-tips-light"></opower-widget-tips-light>
This widget acts as a summary of practical steps for customers to take after seeing a summary of their energy use. It is well-suited for a location near other summary widgets such as Energy Use Overview or Highest Energy Use Days. When viewed together, these widgets make it easy for customers to see current use and take action. Your Delivery Team will work with you to determine the ideal placement.
For more information about the Tips Light, including details about its data requirements and the overall user experience, see the Tips Light description in the product overview.
