Widget Names
When embedding widgets, use the following widget names. The full embedding code is also provided which includes any required instance names:
The full embedding code provided for widgets below includes the default widget and instance names. Contact your Delivery Team to determine and receive any additional widget instance names if you embed multiple versions of widgets in your environment.
Feature Widget Names and Full Embedding Code
Account Center widget-communication-preferences
Full embedding code:
<opower-widget-communication-preferences opower-instance="widget-communication-preferences"></opower-widget-communication-preferences>
Affordability Savings Hub For the authenticated workflow, you must use widget-lmi-survey-programs, and define the opower-instance to embed the survey questions on an authenticated webpage. The webpage must exclude footers and side navigation panels. The full embedded tag is:
<opower-widget-lmi-survey-programs opower-instance="widget-lmi-survey-programs"></opower-widget-lmi-survey-programs>
For the pre-authenticated workflow, follow the same steps but embed the survey questions on a pre-authenticated webpage. The full embedded tag is:
<opower-widget-lmi-survey-programs opower-instance="widget-lmi-survey-programs-easyopen-full"></opower-widget-lmi-survey-programs>
Bill Comparison widget-bill-compare-enhanced
<opower-widget-bill-compare-enhanced opower-instance="widget-bill-compare-enhanced"></opower-widget-bill-compare-enhanced>
Bill or Usage Forecast widget-bill-forecast
<opower-widget-bill-forecast opower-instance="widget-bill-forecast"></opower-widget-bill-forecast>
Bill Guide widget-bill-guide
<opower-widget-business-profile opower-instance="widget-business-profile"></opower-widget-business-profile>
Business Profile widget-business-profile
The same opower-instance can be used for authenticated or pre-authenticated workflows. The full embedded tag is:
Confirmation Message widget-bite-sized
<opower-widget-bite-sized opower-instance="widget-bite-sized"></opower-widget-bite-sized>
Data Browser widget-data-browser
<opower-widget-data-browser opower-instance="widget-data-browser"></opower-widget-data-browser>
Demand Heatmap widget-demand-heatmap
<opower-widget-demand-heatmap opower-instance="widget-demand-heatmap"></opower-widget-demand-heatmap>
Energy Use Overview widget-usage-overview
<opower-widget-usage-overview opower-instance="widget-usage-overview"></opower-widget-usage-overview>
Green Button widget-usage-export
<opower-widget-usage-export opower-instance="widget-usage-export"></opower-widget-usage-export>
Guest User Access widget-guest-user-access
<opower-widget-guest-user-access opower-instance="widget-guest-user-access"></opower-widget-guest-user-access>
Highest Energy Use Days widget-highest-day-of-use
<opower-widget-highest-day-of-use opower-instance="widget-highest-day-of-use"></opower-widget-highest-day-of-use>
Home Energy Analysis - Authenticated Workflow
For the survey questions, you must use widget-survey, and define the opower-instance, to embed the survey questions on a separate webpage. This webpage must exclude footers and side navigation panels. The full embedded tag is:
<opower-widget-survey opower-instance="widget-survey-full"></opower-widget-survey>
For the pre and post survey experience you must embed both widget-survey and widget-usage-categories together on the same webpage, and define the opower-instance attribute as part of the embedded tag. Only one experience is displayed to customers at a time. The full embedded tags are:
<opower-widget-survey opower-instance="widget-survey-splash"></opower-widget-survey>
<opower-widget-usage-categories opower-instance="widget-usage-categories"></opower-widget-usage-categories>
Pre-Authenticated - EasyOpen Workflow - Pre-Authenticated Workflow
You can allow customers to access the survey without logging in to their utility account.
For the survey questions, you must use widget-survey to embed the survey questions on a separate webpage. This webpage must exclude footers and side navigation panels. The full embedded tag is:
<opower-widget-survey opower-instance="widget-survey-easyopen-full"></opower-widget-survey>
For the pre and post survey experience you must embed both widget-survey and widget-usage-categories together on the same webpage. Only one experience is displayed to customers at a time. The full embedded tags are:
<opower-widget-survey opower-instance="widget-survey-easyopen-splash"></opower-widget-survey>
<opower-widget-usage-categories opower-instance="widget-usage-categories-easyopen"></opower-widget-usage-categories>
Home Energy Analysis Call-to-Action widget-hea-cta
<opower-widget-hea-cta opower-instance="widget-hea-cta"></opower-widget-hea-cta>
Home Energy Analysis Light widget-usage-categories-overview
<opower-widget-usage-categories-overview opower-instance="widget-usage-categories-overview"></opower-widget-usage-categories-overview>
How Businesses Use Energy
widget-business-disaggregation
Full Embedding Code:
<opower-widget-business-disaggregation opower-instance="widget-business-disaggregation"></opower-widget-business-disaggregation>
Mini Bill Comparison widget-mini-bill-compare
<opower-widget-mini-bill-compare opower-instance="widget-mini-bill-compare"></opower-widget-mini-bill-compare>
Neighbor Comparison widget-neighbor-comparison
<opower-widget-neighbor-comparison opower-instance="widget-neighbor-comparison"></opower-widget-neighbor-comparison>
Next Best Action widget-next-best-action
<opower-widget-next-best-action opower-instance="widget-next-best-action"></opower-widget-next-best-action>
Peak Time Rebates widget-peak-time-rebate
<opower-widget-peak-time-rebate opower-instance="widget-peak-time-rebate"></opower-widget-peak-time-rebate>
Portfolio View widget-portfolio-view
<opower-widget-portfolio-view opower-instance="widget-portfolio-view"></opower-widget-portfolio-view>
Rate Comparison widget-rates
<opower-widget-rates opower-instance="widget-rates"></opower-widget-rates>
Rates Light widget-rates-light
<opower-widget-rates-light opower-instance="widget-rates-light"></opower-widget-rates-light>
Near Real Time Usage widget-real-time-ami
<opower-widget-real-time-ami opower-instance="widget-real-time-ami"></opower-widget-real-time-ami>
Solar Savings Insight widget-solar-savings
<opower-widget-solar-savings opower-instance="widget-solar-savings"></opower-widget-solar-savings>
Solar Welcome Experience - How Solar Works widget-how-solar-billing-works
<opower-widget-how-solar-billing-works opower-instance="widget-how-solar-billing-works"></opower-widget-how-solar-billing-works>
Tips Light widget-tips-light
<opower-widget-tips-light opower-instance="widget-tips-light"></opower-widget-tips-light>
Tips List
widget-ways-to-save
This widget is part of the Ways to Save widget. This widget can be configured to display the Tips List user experience by default rather than the Ways to Save experience.
<opower-widget-ways-to-save opower-instance="widget-ways-to-save"></opower-widget-ways-to-save>
Ways to Save widget-ways-to-save
