Personal Tracker
The Personal Tracker provides customers with up to one year's comparison of their current year's usage to the previous year. It offers a range of data scenarios, displaying usage information across as few as three bills or as many as two full years of bills. The module includes an evaluative statement that assesses the customer's performance, a bar chart for visualization, seasonal helpers, and insights into why their energy use may have increased, decreased, or remained the same. This module may be used as a replacement for the Self-Comparison module located on the back of the Progress Report
Appears in: Progress Report.
Personal Tracker Example
This image is an example of the Personal Tracker module user experience of an electric-only customer.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Header The header varies by fuel type and available data. The utility may select alternative headers. Default: Your energy use compared to last year |
Required
Bar Chart Colors The bar chart colors maybe changed. Default: By default, the chart colors match the utility branding. |
Required
Primary Insight The primary insight varies by fuel and report type. |
Required
Secondary Insight The primary insight varies by weather data and report type. |
Required
User Experience Variations
The user experience of the feature may vary for customers and utilities depending on their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see the Personal Tracker description for Home Energy Reports v3 in the Oracle Utilities Opower Energy Efficiency Cloud Service Overview and go to the User Experience Variations section.
