Connections Panel
This panel displays a map of the selected node and the nodes connected to the selected node. It is used to visually represent the dataflow or path of a given point through the Oracle Utilities Live Energy Connect (LEC) Server. Each node in the map will be listed with the name of its VMD, its own name, and the type of node it is.
You can select any node that appears in the Connections panel. It can be useful to select nodes in a configuration from the Connections panel so that you don’t have to search for them in the Node Table.
In the Connections panel, you can specify a limit on how close connected nodes have to be to the selected node in order to appear in the map.
Image of Connections Panel
The above screenshot from LEC Configuration Manager shows the map of the dataflow around a selected node and its connected nodes in the Connections panel. The #clientPoints inside VCC_A VMD is the selected node.
Back to Top
