Current Alias Panel
The Current Alias panel displays the configuration alias currently selected, and allows you to switch between different aliases. Multiple configuration aliases can be created, though typically only one is used in a production environment. It also shows the running state of the Oracle Utilities Live Energy Connect (LEC) Server associated with the current configuration alias and lets you start and stop the server as a Windows process instead of running it as Windows service, which is useful in testing and troubleshooting scenarios.
The following screenshot shows the cfg configuration alias currently selected. Click the name of a configuration alias in the drop-down menu to switch to a different alias. The Running State box shows the LEC server instance associated with this configuration alias is not running.
