Menu Bar
The menu bar organizes the remaining tools in the LEC Configuration Manager and provides quick access to some of the most used features of the software. It also contains a group of buttons used to create connectors between nodes and an easy-to-find button that can be used to stop or start the LEC server.
Again, in addition to providing access to the File, Edit, View, Filter, and Help menus, the Menu Bar consists of buttons that launch the Create Connector tool and allow you to create new connectors. The figure above displays the Create Connector window for creating a TimedConnector.
The following table gives you an overview of each menu bar item.
Item |
Options |
File |
Edit |
View |
Filter |
Help |
Connector |
Use the Connector buttons to create connectors. A connector is represented by an arrow that starts at a source node and ends at a destination node. The types of connectors available are:
| Start / Stop Service |
Use the Start service or Stop service button to start or stop the LEC service for the currently selected configuration alias. |
