Getting Started
The Oracle Utilities Live Energy Connect (LEC) Configuration Manager is a GUI application that gives users the ability to design, modify, and monitor their LEC Server configurations.
Introduction to Live Energy Connect
LEC is a highly configurable middleware product that enables real-time communication between any number of IT and OT systems.
LEC simplifies and reduces the interfaces between OT systems. In the above figure, the gray connectors represent the many possible interfaces between systems in a business without middleware. The solid black lines show how you can use LEC to reduce the complexity of your organization’s systems.
Currently, LEC supports 20+ protocols used in the Utilities industry, including MMS, ICCP (TASE.2), DNP, Modbus, and OPC UA.
This document assumes the reader has access to a recent release of LEC (v7.0.0.0.0 or later). For information about installing LEC products, refer to the LEC Installation Guide or contact My Oracle Support.
Note: LEC was formerly known as LiveData Utilities Real-Time Integration (RTI) Server Platform.
