Getting Started
On this page:
Hardware Requirements
The minimum recommended hardware requirements are:
- CPU: a modern, multi-core processor (2.4GHz or faster)
- Memory: 8 GB RAM
- Hard Disk Space: 500 GM or more
Software Requirements
The operating system requirements for computers hosting LEC are:
- Windows Server 2012, Windows Server 2016, or Windows Server 2019
For development purposes, LEC will also run on Windows 10.
Note: It is possible to run LEC Server using Windows Failover Cluster Manager. For more information, contact My Oracle Support.
Software Included with Installation
The LEC installer will install the following software on your machine. All open source software licensing information can be found in the Oracle Utilities Live Energy Connect Licensing Information User Manual.
- Oracle Utilities Live Energy Connect (LEC)
- Oracle Utilities Live Energy Connect Configuration Manager (LCM)
- Python 3.11.7
- OpenSSL 3.0.13
- Stunnel 5.72
Important: If your machine has an older version of Python 3.x installed, you will need to either uninstall it or upgrade it to version 3.11.7 before installing LEC. Note that uninstalling or changing the version of Python 3.x on your machine may affect other software.
Note: The standard installation includes all the software components required to use Secure ICCP. For information about configuring Secure ICCP with LEC, refer to Configuring LEC for Secure ICCP.
