Installing Live Energy Connect
Use the following steps to install Live Energy Connect (LEC):
- Sign into support.oracle.com.
- Click the Patches & Updates tab and click the Search tab from the Patch Search section.
- Ensure Number/Name or Bug Number (Simple) is selected from the left side of the section.
- In the Product field, type Oracle Utilities Live Energy Connect, and in the Release field, select Oracle Utilities Live Energy Connect 7.1.0.0.0; click Search.
- Check the Updated column to find the most recent release and click the Patch Name.
- Click Download and then click the ZIP link to download the install.
- Unzip the file and click the LiveEnergyConnectSetup EXE file.
- When the installation is complete, you can access the tool from the Windows Start menu by clicking Live Energy Connect and then Live Energy Connect Configuration Manager; you will need to open the tool as an Administrator.
For information about using the LEC Configuration Manager refer to the Live Energy Connect Configuration Manager User Guide.
