Uninstalling Live Energy Connect
Important: Uninstalling Live Energy Connect (LEC) will remove all server configuration files related to the app. Make sure to make a backup of all required files before uninstalling. By default, LEC Server configuration files are located in the C:\ProgramData\LiveEnergyConnect directory.
To uninstall LEC:
- From the Windows Start menu, select Settings, then select Apps.
- Select Live Energy Connect (64-bit) from the list of applications and click Uninstall. The LEC installer will uninstall LEC, but it will not uninstall Python or Stunnel.
