Master Control and Active/Passive Mode
The LEC Server instance, configured as an IFE, hosts a Master Control variable that toggles the instance between Active and Passive modes. A remote OPC UA client can write to this Master Control variable. In this scenario, the remote OPC UA client is one of the application’s OPC UA clients. Writing 1 to a Master Control variable sets the LEC Server instance to Active mode, while writing 0 to a Master Control variable sets it to Passive mode. A remote OPC UA client can also read the Master Control variable to query the instance’s active/passive status. It is useful for the OPC UA client to read the Master Control variable because, even though the OPC UA client knows what Master Control values it has sent, the Master Control variable may be changed by the Heartbeat mechanism or by a cluster controller.
On this page:
Master Control
The Master Control variable is available to read from and write to through the LEC Server instance’s OPC UA server using the following points:
| Read Point | Write Point |
Where <agent> is the name of the actual OPC UA server agent node. For example: |
Note: You can configure the OPC UA namespace and branch for each of these points.
Active Mode
In Active mode, LEC Server will allow the enabling of ICCP associations and OPC UA client outbound connections. However, you must enable each ICCP association explicitly with the VCC’s Association Control variable. Similarly, you must enable each OPC UA client outbound connection by explicitly setting the VMD’s Association Control variable.
Passive Mode
In Passive mode, LEC Server will disable all ICCP associations and OPC UA client outbound connections.
Association Control Variables
Each ICCP VCC has an Association Control variable to enable or disable its associations. Writing 1 to the Association Control variable enables the VCC’s associations, while writing 0 to the Association Control variable disables the VCC’s associations. The LEC Server instance must be in Active mode for associations to be enabled; writing 1 to the Association Control variable has no effect when the instance is in Passive mode.
The name of the connected remote peer VCC is also read via OPC UA server variable.
Association Control variables are available to read from and write to through the LEC Server instance’s OPC UA server. The inbound Association Control variables for reading and writing are as follows:
| Inbound Association Variables | |
Inbound Association: Read Point |
<VCC>/ Where <VCC> is a placeholder for the actual character string used in naming the VCC containing this point. For example: |
Inbound Association: Write Point |
<VCC>/ For example: |
Inbound Connected Peer: Read Point |
<VCC>/InboundPeerName For example: AppTestVcc/InboundPeerName |
| Outbound Association Variables | |
Outbound Association: Read Point |
<VCC>/ Where <VCC> is a placeholder for the actual character string used in naming the VCC containing this point . For example: |
Outbound Association: Write Point |
Outbound Connected Peer: Read Point |
The outbound Association Control variables for reading and writing are as follows: <VCC>/ For example: |
