Node Monitor
After you have a working configuration, you can start the configuration and examine the contents of each node in the Node Monitor.
To examine the nodes in your configuration:
  1. Click the Node Monitor tab at the bottom of the Node Table.
  2. Click Start service in the LEC Configuration Manager header if LEC Server is not already started.
  3. Click each of the checkboxes next to the nodes whose values you want to monitor.
    Image of Node Monitor
Back to Top
