Provisioning a New System
Starting with a Windows Server and install LEC Server software with a base IFE configuration, the OEM application will be able to push the batch files of specific VMDs, VCCs, association control variables, and device points to each system. For each system, the OEM application will also be able to specify IP addresses for all VMDs, VCCs, and utilities, and then push these addresses to their respective systems.
Oracle LEC Server Requirements
The hardware requirements depend on the specific application. Most applications can run on an entry-level Microsoft Windows Server. The following are the minimum requirements for a computer hosting an LEC Server instance:
- Multi-core processor (2.4 GHz or better)
- 8 GB RAM
- 500 GB Hard Disk
- Any currently supported Microsoft Windows Server OS
