Release 7.1.0.0.18
Note: To install the Oracle Utilities Live Energy Connect 7.1.0.0.18 patch, refer to the instructions in the Oracle Utilities Live Energy Connect Installation Guide. The patch is available to download from customer’s My Oracle Support portal.
Enhancements
The following are new and enhanced features for Oracle Utilities Live Energy Connect.
- Fixed crash associated with change in master control state for GE ISx tags.
- Set log file security settings based on those of log directory.
- Fixed bug that rejected valid ACSE/Secure ICCP X.509 certificates with multiple Relative Distinguished Names.
- Removed M2Crypto library.
Known Issues
This section focuses on the known issues at the time of this release.
Oracle Utilities Live Energy Connect Configuration Manager
- In previous releases (called LiveData Utilities RTI Server), running multiple instances of the Configuration Manager simultaneously could lead to unexpected behavior isolated to the Configuration Manager application.
- Do not run multiple instances of the Configuration Manager on one machine simultaneously. The Configuration Manager is designed to edit and monitor multiple server instances by using configuration aliases.
