Release 7.1.0.0.19
Note: To install the Oracle Utilities Live Energy Connect 7.1.0.0.19 patch, refer to the instructions in the Oracle Utilities Live Energy Connect Installation Guide. The patch is available to download from customer’s My Oracle Support portal.
Enhancements
The following are new and enhanced features for Oracle Utilities Live Energy Connect.
  • Fixed bug in ACSE certificate validation for Secure ICCP.
  • LEC can subscribe to GE ISD points before connection to remote ISX server.
  • Internal fixes and improvements.
Known Issues
This section focuses on the known issues at the time of this release.
  • In previous releases (called LiveData Utilities RTI Server), running multiple instances of the Configuration Manager simultaneously could lead to unexpected behavior isolated to the Configuration Manager application.
  • Do not run multiple instances of the Configuration Manager on one machine simultaneously. The Configuration Manager is designed to edit and monitor multiple server instances by using configuration aliases.
