Oracle Utilities Live Energy Connect v7.1
Current Version: 7.1.0.0.44
Note: To install the Oracle Utilities Live Energy Connect 7.1.0.0.44 patch, refer to the instructions in the Oracle Utilities Live Energy Connect Installation Guide. The patch is available to download from customer’s My Oracle Support portal.
Enhancements
The following are new and enhanced features for Oracle Utilities Live Energy Connect.
Oracle Utilities Live Energy Connect Server Enhancements
Fixed regression in scriptRun RTX causing crash running legacy customer configurations.
ISX: Change timestamp offset logic between GE SCADA timestamps and Oracle NMS timestamps.
ISX: Moved timestamp offset value to LEC INI file servxnt.ini, GeTimeOffset=283996800.
ISX: Fixed error where active tags were not updated when IST connection cycled.
ISX: Correct multiple log messages assigned to wrong log category.
ISX: Updated/additional quality code support from GE SCADA
Known Issues
This section focuses on the known issues at the time of this release.
Oracle Utilities Live Energy Connect Configuration Manager
- In previous releases (called LiveData Utilities RTI Server), running multiple instances of the Configuration Manager simultaneously could lead to unexpected behavior isolated to the Configuration Manager application.
- Do not run multiple instances of the Configuration Manager on one machine simultaneously. The Configuration Manager is designed to edit and monitor multiple server instances by using configuration aliases.
