High Level Messages
CalcAdapter accepts high level messages to refresh the calculated-measurement definitions, dependent measurement mappings, and calculation rules used by the SCADA Calculation Engine. Update the corresponding database configuration or SRS rules before requesting a reload. The messages below select which runtime information is refreshed.
The common Service high level messages in the Configuration Guide also apply unless an adapter-specific handler overrides them. The entries below describe adapter-specific behavior and explicitly include inherited messages used in this chapter.
Send a request to the running service with:
Action any.CalcAdapter <command> [arguments]
Use the configured process name if it differs from CalcAdapter. The service target can contain a wildcard; select the intended service when changing state. Command names are normalized to lowercase; argument case follows the individual command. Output normally appears in the target service log. An acknowledgement can precede completion of the requested operation.
In the syntax below, angle brackets identify required values, square brackets identify optional values, and an ellipsis permits repetition. Enter values without the brackets and preserve the spelling and case shown.
Caution: Consult Oracle Support before first using diagnostic or maintenance commands, particularly in production. Commands can modify data, interrupt processing, or generate substantial output. Use sms-stop for routine service shutdown rather than the deprecated stop message.
CalcAdapter
recache_measures
Reload the calculated-measurement definitions and dependent measurement mappings.
reload_rules
Reload calculated-measurement adapter configuration rules.
