Name | Data Type | Description |
parameter_name | VARCHAR2(32) | The name of the parameter. Required. |
parameter_value_1 | VARCHAR2(64) | Required parameter value. |
parameter_value_2 | VARCHAR2(64) | Optional parameter value. |
parameter_value_3 | VARCHAR2(64) | Optional parameter value. |
Parameter | Description |
sourceDBServiceName | Sets the database service name, server name, and port details for the forecast updates table. • parameter_value_1: server name. The default value is DB. • parameter_value_2: port number. • parameter_value_3: database service name. |
operationalService | Sets whether the adapter is running on the operational service network or the enterprise service network. • parameter_value_1: Yes | No • Yes: operational service network • No: the enterprise service network |
useSqlLoader | Sets whether to use SQL Loader or NMS Import to load the data into NMS tables. • parameter_value_1: Yes | No • Yes: SQL Loader • No: NMS Import or other process |
forecastDir | The directory containing the forecast CSV file. |
numDataCol | Define rule to specify the number of columns in raw CSV |
dermsBidColumnMap | Defines the CSV columns. • parameter_value_1: column name. • parameter_value_2: column number. The column numbering starts with 0, which is the first column in the table. The standard configuration is defined as follows: • Column 0 = ForecastDate (mm/dd/yyyy HH24:MI:SS). Note: All time stamps should be provided in Coordinated Universal Time (UTC). • Column 1 = ResourceName • Column 2 = Availability Pricing • Column 3 = Utilization Pricing • Column 4 = Bid kW • Column 5 = Bid kVAr • Column 6 = Minimum Output |
dermsColumnMap | Defines the CSV columns. • parameter_value_1: column name. • parameter_value_2: column number. The column numbering starts with 0, which is the first column in the table. The standard configuration is defined as follows: • Column 0 = ForecastDate (mm/dd/yyyy HH24:MI:SS) Note: All timestamps should be provided in Coordinated Universal Time (UTC). • Column 1 = ResourceName • Column 2 = PowerSourceType • Column 3 = ForecastValue |
forecastColumnMap | Defines the CSV columns for External Load and Gen CSV file • parameter_value_1: column name. • parameter_value_2: column number. The column numbering starts with 0, which is the first column in the table. The standard configuration is defined as follows: • Column 0 = ForecastDate (mm/dd/yyyy HH24:MI:SS) Note: All timestamps should be provided in Coordinated Universal Time (UTC). • Column 1 = ResourceName • Column 2 = ForecastSource • Column 3 = Forecastobject • Column 4 = ForecastkW • Column 5 = ForecastkVAR |
headerPresent | Sets whether the CSV file has a header row or not. • parameter_value_1: Yes | No |
forecastnumDataCol | Define rule to specify the number of columns in External Load and Gen CSV file |
dermsBidNumDataCol | Define rule to specify the number of columns in the DERMS Bid data CSV file. |
dermsBidColumnMap | Defines the CSV columns. • parameter_value_1: column name. • parameter_value_2: column number. The column numbering starts with 0, which is the first column in the table. The standard configuration is defined as follows: • Column 0 = ForecastDate (mm/dd/yyyy HH24:MI:SS) Note: All timestamps should be provided in Coordinated Universal Time (UTC). • Column 1 = ResourceName • Column 2 = AvailabilityPricing • Column 3 = UtilizationPricing • Column 4 = BidKw • Column 5 = BidKvar • Column 6 = MinimumOutput (minimum capable output for DER) |
dermsDOENumDataCol | Number of columns in a DOE schedule CSV file. parameter_value_1 defaults to 4. |
dermsDOEFileToken | Case-sensitive filename token identifying DOE schedule CSV input. parameter_value_1 defaults to _doe. Include this token in every DOE CSV filename, for example market_doe.csv. |
dermsDOEColumnMap | Maps DOE fields to zero-based CSV column positions. • parameter_value_1 is the field name; parameter_value_2 is the column number. Defaults: ForecastDate = 0 (MM/DD/YYYY HH24:MI:SS, UTC); ResourceName = 1; MaxImportKw = 2 (maximum import capacity in kW); MaxExportKw = 3 (maximum export capacity in kW). |
externalLoadGenFileToken | Case-sensitive filename token for External Load and Gen Forecast CSV files. parameter_value_1 defaults to ExternalForecast. This replaces the filename discriminator formerly configured by LOAD-GEN_EXTERNAL_INPUT_FILE_FORMAT. |
vppScheduleFileToken | Identifies authoritative eVPP schedule CSV and JSON files by a token in the filename. The default is _vpp_schedule. Place these files in the directory configured by forecastDir. |
