Contents of the WebSwitchingImpactedCustomers Folder
• WebSwitchingImpactedCustomers.xdrz: an archive file that includes the entire contents of the WebSwitchingImpactedCustomers folder within Oracle Analytics Publisher. This archive can be opened up with any archive viewer. The archive contains the following files:
• NMS Data Model.xdmz: Oracle Analytics Publisher data model. This file defines the data that is used by the Web Switching Impacted Customer export reports. It contains all the queries that are used to pull the data from the database.
• Templates.xdoz: Oracle Analytics Publisher templates. This file consists of a generic report. Product is currently only configured to export CSV (comma separated value) and XML outputs. These output types do not require a report template as the data is organized based on the database queries defined in the data model. Project templates can certainly be added and additional output types be added through project configuration.
